0
Score
Avatar
Andrew
Asked
iPod touch 4G sleep button broken. why isn't volume button?
History
Hi I surprisingly successfully changed my iPod touch 4th Generation screen by myself but when I tried to turn it back on, I found the sleep button was broken so I had to put it in the charger for a second.
I don't want to have to buy a new part or majorly open up my iPod again so what I'm wondering is, is the cable of the part ripped or is it an easily solved problem. From what I understand, the sleep button and the volume buttons are one part so surely if a cable was torn, they would both not be working.
same thing happened to me have you fixed it?
Juan Pena,
Post Answer
0
Score
Avatar
Jason
367
Answered
PermalinkHistory
I had run into the same issue and i figured it out!!!!
It was the metal spudger tool I was using. I noticed that ever since i bought the set from here I had the same problem with the lock button not working but the volume still functioning. I had never once had that problem before, and i have done a lot of these. I did some experimenting with iPods that were under warranty still and used the tool more and more sparingly. I believe the exact issue came from when I was removing the copper tape that secures the digitizer ribbon. When I would repair the iPod not using that tool at all except to remove that tape I still had that issue. I believe it is the metal conductivity. Solution, use screwdriver with a rubber handle.
Edited by: Julia ( )
Product Image
Metal Spudger Set
Includes four different metal spudger tools — 50+ available at 7.95 each.
0
Score
Avatar
Zach
Answered
PermalinkHistory
My sleep button has now stopped working and I've been told bye the techs at radio shack said that they stop working because of over use.
Add Your Answer
