0
Score
Joe
Asked
Change 3GS backlight coil to iPhone4?
My question is can i use an iphone 3gs Backlight IC not the coil... on a iphone 4?
Would it function the same if i mount it properly, the 3GS backlight IC is slightly larger than iphone
Score
oldturkey0
59.5k
Answered
The iphone 4 uses a PH-AS-IP-00001 and the 3GS a IC 109B. They are two different beasts, and as you already mentioned different dimensions. I am all for fixing things, but in this case I would invest $10 and get the proper IC and coil and not risking a destroyed logic board. Just my 2 cents, good luck.
0
Score
DANIEL
Answered
The screen is very different more pixels to push.so i would think that it would be different on the inside.I have the same problem but it is just a generation jumped.I have a buddy with a oscilloscope and will be checking that asap.I could post a picture to see if they match with what you or someone else reports.
