0
Score
Justin
Asked
iPhone speaker wont play iPod audio, but will sound off ringtones.
I recently got my iPhone pretty wet. I let it dry out and it started working again. Although, it wont play audio from my music files aloud. It will however play audio through ear buds. Also, everytime i get a text or before i unlock the phone, i get a messege that normally comes in about "this accessory is not mean't to be used with this generation of iPhone". I used to get that messege everytime I plugged the iPhone into my Alpine car stereo reciever to play music through my deck. Any suggestions?
Also, I have no volume bar when im playing a song anymore, unless i have the ear buds in.
Edited by: mayer, osvaldo, rj713, and oldturkey03 ( ) , Justin ( )
3
Score
Majesty
12.6k
Answered
Accepted Answer
Unfortunately Apple doesn't cover water damage, my suggestion would be to open the device and give it a thorough cleaning with isopropyl alcohol and check for any physically damaged components. Then you can replace any needed parts here: http://www.ifixit.com/iPhone-Parts
2
Score
shane
25
Answered
i finnaly fixed the damm thing cannt belive it i thought it had been water damage or drool damage due to my 18 month playing the baby apps i cleaned the bottum speakers with an old toothbrush and the blow into it from one speaker at time very hard and it F ing worked happy days it was wrecking my F ing head hope it works for u
2
Score
Tony
25
Answered
I had this issue aswell - OMG it's been driving me crazy! My phone would ring and play music in the car, but no other sound, no text tone, no you tube sound no music without speakers. I tried the tip below regarding cleaning the bottom speakers - AND IT WORKED!! woo hoo it's surprising how clogged it gets just from being in your pocket! As suggested, get a toothbrush and something fine and sharp, scrape the crap then brush away :-) I hope this works for you too!! xx
0
Score
damian
35
Answered
0
Score
danny
Answered
0
Score
Chris Green
17.2k
Answered
0
Score
George
Answered
I also have this problem with my iPhone 4s (6 months old). For some reason my phone has suddenly stopped playing music or any sound other than ringtones through the speakers OR headphones plugged in, however if I receive a call it does ring and likewise if I am choosing a ringtone in my settings, it also rings outloud.
However play any of my music or watch videos on YouTube or online and it is completely mute whilst the song or video can clearly be seen ticking along.
I am unable to increase (or decrease) the sound bar using the side control buttons.
I have checked sound limits in settings as One person suggests above however I had no restrictions on it so it's not that. I don't think I've got my phone wet in the last few days but it has been raining a lot so maybe a tiny bit of atmospheric moisture has entered it?
It is strange though that it will play ringtones perfectly well- crystal clear as ever but no music. Frustrated. Any further advice before I send it off would be very much appreciated. Cheers g
I am having the exact same problems as George with my Iphone 4 and I just can't figure it out some more help on this problem would be great.
The likely answer is that the microphones, or the whole dock connector, is damaged. The ear buds can play audio because they run on a different audio output system than the regular audio output. This means that the built-in microphone for use without ear buds is separate than the audio output system designated for use with headphones. It is most definitely built-in microphone damage. However, if it does play some variants of audio, the problem might be involved with the software. Try restoring your phone through iTunes. If software fixes do not work, it is probably a hardware problem. You could buy a new dock connector from iFixIt, and install it into you iPhone. Hope this helps! Timothy Goltser, iTweakTech
0
Score
George
Answered
Hi folks. My issue has been resolved after no real help from apple or vodafone, I tried restoring it through iTunes and then synced it with my back up through iTunes. After a couple of times doing this it starting functioning normally again altho weirdly not straight away but a few hours after I restored it. Think there is just a gremlin in these new and cheaply manufactured (in china) iPhone models. Not very robust and I'm not very impressed but at least this now works. Good luck!
0
Score
Lauren
Answered
I also have the problem. Will ring, but no music, my GPS lady doesn't talk and any of the alerts aren't working either. I talked to Apple and they said it's a software issue, however I did not pay for the support so I am screwed. I will have to pay $160 for them to fix it!! Sound's like their problem.
0
Score
Anish
Answered
I had faced this problem after my iphone 4s was water damaged. I opened it up and cleant the dock with alcohol( Please use a better chemical to clean) It worked for few hours and then again got docked( No sound on ipod etc ) I again opened it up and cleant it and let it dry for some time and now its working fine no problem at all. There is also a chance of the dock connector not functioning. You can easily replace it if possible and your problem will be solved
0
Score
Greg
Answered
0
Score
michael
Answered
