0
Score
Avatar
Gillian
Asked
Disc drive won't let me put a disc in, nothing in there
History
I can't put a disc in, there is something blocking me from putting one in, right at the front, and there isn't a disc in it - i have tried rebooting, restarting, ejecting (even though there isn't a disc in it), etc. It did this before, and fixed itself somehow, but it's not budging now. Feels mechanical, like some part of the eject mechanism is stuck on eject and not going back in???
Did you have any luck on this issue?
wes,
Post Answer
0
Score
Avatar
wes
521
Answered
PermalinkHistory
If you are unable to push the disc in at all then it certainly does sound like a mechanical issue. It sounds as though the mechanism that stops you from inserting a disc when another disc is present has come loose. I would recommend replacing the drive rather than trying to repair it, but it may be worthwhile removing the superdrive to take a physical look to make sure nothing has sneaked its way inside.
Hope this helps,
Wes
0
Score
Avatar
tommyelliott59
Answered
PermalinkHistory
Press and hold the mouse or trackpad button down when you power it on and keep holding it down. This forces a disk eject, or at least tells the mechanism to to go through its eject cycle. This may move the mechanism to it's fully open position for you.
Add Your Answer
