3
Score
Jim
37
Asked
Put battery in incorrectly, now DSI wont work?
I cleaned the directional buttons on my sons DSI, checked to see if they worked before putting it back together, I put the battery in the wrong way now the DSI wont work - any sugestions greatly appreciated
Edited by: oldturkey03 ( ) , Jim ( ) , Walter Galan ( )
4
Score
pollytinto
39k
Answered
Accepted Answer
I'd open the dsi following the guide to the right under the photo. Remove the d- board (the little mini board that the battery sits on) turn it over and you will find the F1 fuse, check with a multimeter but I suspect the greatest damage you've done is blown that fuse. You can buy the d-board separately on ebay. I bought mine for under 5uk pounds. It's a whole heap cheaper than a new motherboard..
There is is an F2 fuse on the motherboard that may be blown. Also many times people pull the red or black wire out of the socket (slightly and looks good but isn't) that connects the power board to the motherboard when unattaching it or pull the header up slightly on the motherboard. I would check for continuity between the battery connecter and those points. I would also check to see if the prongs on the battery connector are in there correctly.
Score
Jake Devincenzi
25.6k
Answered
Yes, as Nick said, you most likely did fry your motherboard. The DSI does not have any sort of reverse polarity protection, so trying to run it with the battery in backwards will fry the motherboard. Unfortunately, you will probably need to replace the motherboard. Luckily, we have a guide for doing so right here!
Hope this helps! Good luck; let us know how it goes!
Edited by: Jake Devincenzi ( )
0
Score
nick
15.3k
Answered
This goes along with me saying you fried the motherboard
If it's the motherboard, you should buy a DSi on ebay with a broken screen but good motherboard to fix it, this is the only way to do it fiesably
follow this to check for visible damage like burnt components, burns in the motherboard and such
if there are any burnt parts, you are propably in for a motherboard swap, however, if there is no damage, you may be in for a motherboard anyway, the damage did not create any marks
You my have fried the motherboard doing that
nick,
