0
Score
Avatar
James Smith
Asked
How can I clean the inside of dust?
History
I've had my 20" iMac for some time and I am concerned that dust in accumulating on critical parts. Is there a way to blow of vacuum it out without disassembling the front?
Thanks for the reply. I appreciate the fast response. What I was thinking about was using a vacuum to suck from the bottom (entry) vents. Perhaps at the same time, blowing air in the top (exit) vents. I'm not even certain this would be necessary as the temps and fan speeds are still nominal even though I've had the sysem for almost three years. Still, preventive maintenance is usually cheaper and faster than repairs.
James Smith,
Post Answer
2
Score
Avatar
Phillip Takahashi
9.5k
Answered
PermalinkHistory
Unfortunately there is no effective way to blow dust out of the iMac without disassembly. Blowing air in through vents would just agitate a limited amount of dust which would likely just re-settle inside the computer. Display removal actually isn't too bad with these machines and our display guide will show you exactly how it's done!
Add Your Answer
