Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
Can't hear from incoming calls unless on speaker phone
Hello,
My Iphone 3G has this problem since I changed the battery. I can hear the other end no problem when it is an outgoing call. I can't hear the other end if it is an incoming call but works if I use speaker phone. Anyone can help please?
Add a comment
1 Answer
I don't know if this is the correct answer, but I would try changing the front panel assembly. I don't know why charging would cause this to happen, but it may just be coincidence.
Here is the guide for changing the front display assembly. You can pick them up pretty cheap on eBay.
Ryan
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,128
