0
Score
Avatar
matt
Asked
How Do I Repair/Mount my HD if Disk Utility does not work?
History
My mac mini has recently bit the dust. I did a hard shut down by holding down the power button. Since then I have not been able to bring it back. It started with a folder with a ? in it. Sometimes it sits at the apple logo, and other times it goes to a gray screen and just reboots eventually. I am running Snow Leopard, and I have booted from the install cd. I have tried running Repair Disk in Disk Utility, but I receive the following error: "Invalid node structure Invalid B-tree node size The volume could not be verified completely. Volume repair complete. Updating boot support partitions for the volume as required. Error: Disk Utility can't repair this disk...disk, and restore your backed-up files."
In the pop up window it says "Disk Utility stopped repairing "macintosh HD" Disk Utility can't repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. On the left hand side of the window I see 60.01GB ST96812AS Media, and then I see Macintosh HD offset underneath. The Macintosh HD is in light gray and is not mounted. When I try to Mount it it gives me an error and tells me to repair the disk.
My question is do you think Disk Warrior would work or something like that software? I tried to do an Archive and Install, but since the HD won't mount I can't do an installation. Is my HD dead?
Any help would be appreciated!
Sincerely,
Matt
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
Disk Utility has given up on your old hard drive. Time for a new drive. You can use an external enclosure or an adapter and hook up the new drive, then use your Disk Warrior to try to recover your data. I would format the new drive andinstall a system on it before trying to recover anything. Here's the adapter I use: http://eshop.macsales.com/item/NewerTech...
From the size of your hard drive I would guess you have a Apple Mac mini "Core Duo" 1.66 Specs Identifiers: Early/Late 2006 - MA206LL/A* - Macmini1,1 - A1176 - 2108 which uses a standard 2.5" SATA hard drive.
mayer,
Add Your Answer
