8
Score
Avatar
Kyle Wiens
3.7k
Asked
What should I do after I spill liquid on my device?
History
We get this question all the time. For some reason, people are very particular about the type of fluid. It's very important for people to tell you whether it was apple or orange juice that their kid spilled on their MacBook Air.
So what do you suggest? What has worked for you in the past?
Edited by
Post Answer
10
Score
Avatar
machead3
8.9k
Answered
Accepted Answer
PermalinkHistory
Pull the power cord and remove the battery if possible.
No hair dyers or any forced air on/into a closed device! you'll only be spreading any liquid not drained around inside where you can't see or get at it.
In my opinion 72hrs is a conservative wait time for drying- hours or a day mean nothing Best way to dry it is to seal it with a desiccant like silica packs (though even something like pasta can work in a pinch) or in a room with a dehumidifier.
Liquid and electrons don't mix. You really ought to open and dismantle the device as much as possible so that you can clean up, rinse off any residue that's right if it's already wet you can wash it and clean it so that there will be no corrosion occurring later. Spraying with an electronic contact cleaner, and/or 99% alcohol will also speed the drying process.
Forced air on the open parts is OK, but if you're in a humid environment packing up with desiccant in a trash bag or rubbermaid container and making changes over three days or so would be better.
There's been a lot of well I spilled on laptop my keyboard, but it still worked at first..., If you're lucky enough not to kill it straight off, then at least remove, clean and dry the keyboard best as possible before continued use. With most laptop designs there's ''nothing between the bottom of the keyboard and the RAM, FAN, Optical Drive, and all the other parts of the logic board but AIR
N.
Edited by
I have to say that your comment "no forced air" is not the first one I've seen. However, on a plane trip from Phoenix to Boston, I spilled water on my netbook. I immediately unplugged the battery, and wiped it down but it wouldn't function at all. When I got to Boston, I went into the bathroom (I cannot recall if it was the train station or the airport) where they had these super high fast air hand dryer things that both suck and blow warm air to dry your hands. It worked. I just pulled back the screen as far as it would go and held it in there for 3-5 minutes. It worked perfectly. However, I will say if it was beer or wine or any other "gets sticky when it dries" liquid, I wouldn't have tried the hand dryer option, and certainly would have not used one of those older REALLY hot hand dryers. But the new super high speed air/vacuum units did the trick.
Nate,
5
Score
Avatar
Miroslav Djuric
32.5k
Answered
PermalinkHistory
I actually wrote an article called "Spills that Kill." You can read the full text here.
Excerpt from the article:
"Here’s a few tips in case a spill ever happens to you, whether it’s on a laptop any other electronic product:
  • Don’t panic. Panic just complicates things.
  • Remove power to your device as fast and soon as possible. If that means not saving your blog post, so be it. You can always view the auto-save, but there’s no auto-save function for your logic board.
  • Shake out any liquid as soon as the device is turned off.
  • Let the device dry in a manner that is conducive to getting the liquid out. If it’s a laptop, place it upside-down on a counter and let it relax for a day or two.
  • Possibly disassemble parts of the device to verify that it’s dry, and/or to use a hair dryer to finish the job.
  • Cross your fingers, and turn the device on."
5
Score
Avatar
leibnitz
61
Answered
PermalinkHistory
I am an electronics engineer, so trust me when I say;
No hair driers please!
Hair driers can actually melt solder, depending on solder's composition. Improper heating of solder will result in porous solder with increased electrical resistance, also known as "cold" solder. You need a microscope to actually be able to see this.
Best possible solution is to disassemble the computer as suggested on other answers. Use DIELECTRIC spray, it is specially designed to clean electronic components without damaging the PCB (Printed Circuit Board) or electronic components, you can use a tooth brush if you are extremely careful. Do not do this in a hurry, this requires a lot of patience.
When disassembling, it is extremely important to use antistatic precautions, specially if you live in a place where air is dry. Or house heating is used, especially electric heating.
At the very least you must discharge yourself by touching an electrical ground. Like your computer's chassy (if its metallic) while STILL connected with a properly grounded power cable (you must touch where there is NO paint, usually the back of a desktop would be unpainted).
If you want to be really safe you would need to buy an anti static wrist strap so that you are connected to ground ALL the time you are working with your computer.
You can get a ground connection from your wall sockets IF your sockets are PROPERLY grounded.
If you are thinking that this is all an exaggeration consider that you could have anti static shoes, anti static pants, ant static shirt and anti static gloves, also the floor you step on could be anti static.
If data on your computer is important, you can remove the Hard Drive and read its information by connecting it to another computer, even if yours does not work any more.
You can do it!
Good luck!
2
Score
Avatar
Reed
343
Answered
PermalinkHistory
I've heard that covering the device with rice is a good way to help suck water out :)
Not a bad idea, but you might want to make sure you rotate out the rice. I almost want to create some experiments to see if this works...
Nat Welch,
I tried the rice method a couple of times, but it's a pain getting that rice out of the machine afterwards. It even creeps under the logicboard, etc. I use silicia bags instead now.
remacberlin,
Score
Avatar
miguelb
149
Answered
PermalinkHistory
I helped a friend with an iPhone 3G that took a shower in a cup of tea and I just left the device open for 2 days and reassembled it.
In his case the LCD got some black lines and the battery died.
After the replacement of these parts it was new again.
Before doing this REMOVE THE BATTERY if possible.
In the case of salt water, juice, coffie you can wash it with distilled water, in the case of salt water even with tap water is better then nothing.
Then just leave it drying for some time if possible open.
There is a more specific product that sometimes I use that is Kontakt Chemie PCC.
http://www.soselectronic.com/a_info/reso...
Edited by
Score
Avatar
mac605
97
Answered
PermalinkHistory
Call from another office: "Macbook flooded with cup of coffee! Help!". "Remove battery, put some paper towels on keyboard, turn it upside down, send it to me".
It was really flooded, even HD was covered with coffee, of course HD containing VeryImportantDataNeededASAP. I removed logic board from HD and washed it in denatured alcohol, dried, reassembled, and it worked.
Macbook warranty was over, so I decided that I have nothing to loose. I took another Macbook, went to ifixit.com and started disassembling it completly - http://bit.ly/2cDOva. I washed keyboard and logic board in denatured alcohol too, lefr it for weekend to dry, then reassembled it.
It worked like charm, I was pretty surprised :)
and then accidentally I spilled denaturated alcohol on another Macbook, that forced me to dissasembly it too (thx ifixit again) and learned me a lesson: ALWAYS SEAL THE BOTTLE!!!
Score
Avatar
Designprof
49
Answered
PermalinkHistory
I wouldn't recommend Acetone as it is a solvent for plastics and could do serious damage to case parts. However, in addition to Isopropyl (Rubbing) Alcohol, I would recommend a rubber cement thinner like "Bestine", found in art supply stores.
Score
Avatar
Designprof
49
Answered
PermalinkHistory
In the case of digital cameras, remove the battery asap. Otherwise the flash charging circuit could short out sending high voltage across the motherboard.
Then use one of the appropriate iFixit procedures to remove the back cover of the camera. Let it air dry, for a week before touching it. Reassemble and hope for the best.
0
Score
Avatar
Anky
109
Answered
PermalinkHistory
Well, the simplest thing is to [though it's not that simple] dismantle your product and clean. There is little you can do other than that.
0
Score
Avatar
Oric
7
Answered
PermalinkHistory
I remember from my chemistry classes in collage that we would use acetone to dry beakers as it would remove any remaining moisture. I have also seen on u tube that isopropyl alcohol has been used in addition to rice (in a sealed container) that was mentioned in an earlier response.
0
Score
Avatar
fredflintstone
Answered
PermalinkHistory
Dessicant available in a drug store works really well too. Just seal it up with the device in a box or cooler, and leave for a few days.
0
Score
Avatar
brem
55
Answered
PermalinkHistory
I would say remove any form of power main or battery
Turn laptop back over onto side fluid entered so can run back on itself and exit
If you are confident remove ram covers Ram some HD and CD/DVD drives can also be removed usually with 1 or 2 screws dab dry if needed before fluid dries as may become hard or sticky Spraying with an electronic contact cleaner or alcohol based to stop corrosion later .
Leave to dry for some days maybe in airing cupboard someware dry not hot .
When powering back up leave all items above removed were just looking to see if it powers up think battery might be best first option as lower power level and AC rather than hitting it with DC higher power level.
Then power down add ram boot up again power down add CD/DVD boot again Now was thinking might be worth running live Linux disc before adding hard drive to test USB sound and anything else you can think of Not sure if it would just be wasting time or a good way of testing before adding hard drive Before this step might be worth connecting HD to adapter with other pc and copy just in case.
0
Score
Avatar
Trayvin
Answered
PermalinkHistory
Put it in a bag of rice for a couple of hours
0
Score
Avatar
Paull
Answered
PermalinkHistory
Applies to any electronic device:
De-power as soon as possible
Disassemble as soon and as much as possible
wash with Alcohol, rubbing alcohol, denatured alcohol, or surgical spirit is best. Even Dunking completely is ok
Alcohol will not do damage, and because it is Hygroscopic, it absorbs any residual waters from the flooded item, then all that remains is to allow the residual alcohol to also dry out. Keep in mind capillary action can keep the liquid under SMC's for some time, so some time for drying out is recommended. Dont add heat!
If the flooded item was drenched in Coffee, Soda, fruit juices, you may as well re-flood the disassembled components with fresh water before the alcohol, as you need to also remove sugars, acids, and whatever else may be contained therein
Sorry, same applied for Vodka, Brandy, Scotch etc, they are not pure enough alcohol, heh
0
Score
Avatar
Nate
109
Answered
PermalinkHistory
I literally just spilled beer on my laptop last night and it wasn't a pretty little dot of beer either on the palm rest. Just picture foam all over my keyboard and touch pad.
Problem: I needed to update a financial spreadsheet last night so I was unable to wait. I had to fix this asap.
These are the simplified steps I took and then below I'll explain why and how you can save your laptop without having to let it sit for days/hours what not if this happens to you.
Beer Spill Save:
1. Immediately unplugged, popped out battery and tilted the laptop forward in an inverted V shape on my table so fluid ran out of the laptop onto the table while wiping the laptop off.
2. Wiped off table and laid down place mats/towels/whatever for a dry work space.
3. Disassembled (hard drive first, keyboard, palm rest) only what I had to in order to access affected areas as quickly as possible.
4. Dabbed everything off with a towel first and cleaned with alcohol on a q-tip. Inspected everything else to ensure nothing else was contaminated.
5. Let sit for a few minutes (mostly to take a deep breath and drink the rest of my beer across the kitchen) and reassembled/tested.
Note: If you submerge something in liquid, or let it sit long enough with the liquid while the power is on, this technique will probably not work for you. The trick is REMOVE ALL POWER AS QUICKLY AS POSSIBLE. Also some laptop models are just made so they are impossibly difficult to disassemble / repair.
TIPS TO SAVING YOUR LAPTOP:
Pre-spilling beer techniques:
1. (Obvious) keep your drinks away from your laptop.
2. Have no bones about it. Something will be spilled on your laptop at some point for sure. Maybe not by you, but assume it will happen. Especially if you have animals or kids or both.
3. Have the tools and manual to disassemble your laptop (either before or right after you buy it). Take it one step further and don't buy a laptop if you cannot find the manual for it. In fact, when I bought this laptop, I did so specifically because it only has two sizes of screws
4. Practice removing the battery and power cord until you can do it quickly (within 2-3 seconds is best). Don't buy a laptop that requires special tools to remove the battery. Laptop fatalities can be greatly reduced if you know this.
5. Know that chances of saving your laptop are greatly increased if the liquid spilled on it is just water. Beer, wine, anything with sugar or milk or what not will be a pain but not always fatal.
POST spilling techniques.
See Beer Spill Save above.
If you aren't home, don't have tools, etc, there's still hope.
1. Unplug and remove the battery as quickly as possible. Removing power reduces the chances you'll arc a connection with whatever you spilled. It's not guaranteed but it's the best shot you have.
2. Dab off the unit as quickly as possible with napkins and paper towels or anything else you can find (other people's clothes, etc) and swap dry towels for the damp ones as much as possible.
3. Keep the unit wrapped in napkins or paper towels. Swap with dry ones when necessary.
4. Follow steps 1-5 (Beer Spill Save) above as soon as possible or bring to a repair shop if you cannot do it yourself.
I've spilled liquids on every laptop I've owned, and it wasn't until I learned my lesson a few times (and a few thousand dollars later) that I learned to avoid fatalities.
Hope this helps.
Edited by
Add Your Answer
