0
Score
Avatar
Fabio
Asked
replaced logic board now can only boot in safe mode
History
After fixing the infamous ATI chip problem a couple of times using the heatgun technique, I finally managed to fry my 2.16GHz logic board...so, after some research I decided to buy a new logic board just to give my laptop some more life...I eventually went for a 2.33GHz board as it's a direct replacement on A1211 models and also because it was the only one I could find at a reasonable price.
Everything went ok, except that I can now only boot in safe mode...a normal boot get stuck on the grey screen and I can't seem to be able to boot from the Snow Leopard disc either...
Anyone has some suggestions/advice on how to fix that?
Did you try a power manager reset (SMC) and a PRAM reset ? After a logic board replacement the board could need a reset to work as it should.
lemerise,
Are you using the gray install disks or retail 10.6 disk?
mayer,
SMC and PRAM reset...no luck...and I'm using a 10.6 retail disk...next thing I'll try: target disk mode - FW cable to another Mac and run Disk Warrior...don't know what else to try...pretty sure it's a software issue...
Fabio,
I had this problem, but it was still the video card that was bad. Booting normal it it would hang on a light blue screen just before your wall paper appears. Booting from disk wouldn't work other.
Rav4Baby,
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
At this point I'd do a reinstall of the 10.6 as there may be slight differences in the software installation for a 2.16 GHz and a 2.33 GHz. I don't know what they might be but it couldn't hurt. Unless the Target Mode machine is a 2.33 GHz, I wouldn't do a system install from it as it will install the system needed for the mother machine.
Add Your Answer
