Cursor stuck in the upper left corner
I just replaced the logic board and optical drive and when I boot up the mouse pad does not work. What should I check 1st?
Update
The built in track pad is not working. I am checking the connection now. I was hoping to find out which connection is the likely problem.
thanks for the help
Score -1
Add a comment
Chosen Solution
Do you mean you're running a USB mouse or the in-built trackpad on the keyboard area? If it's USB the check ports externally for dirt/bent pins and for solder crack internally. If it's the trackpad and you had no previous prioblems then you should recheck your connection there.
Score 4
1 Comment:
Reseat the keyboard connector making sure you haven't bent over any pins on the connector: PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
by
Add a comment
The 4 pins are straight and connector seems fine. Yet no track pad working yet.
USB mouse does work.
Add a comment
Add your answer
John SS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 667
