The current line of iPod touch comprises seven (7) different generations.
2618 Questions View all
Temperature iPod Needs To Cool Down Before You Can Use It
I just moved an entire iPod 4g over into a new backplate, added a new power flex, lcd and battery.
I've been getting the message on the screen after power it up, or trying to use it...
Temperature
I just removed the old thermal paste from under the logic board and put on a fresh coat of Arctic Silver, but, still have the same results.
I've also unplugged and let it sit 15 minutes.
Any ideas?
thanks!
Score 2
Add a comment
Chosen Solution
For reference, I'll leave this post since I googled the heck out of a solution and couldn't find one, maybe someone will stumble upon this.
Seems the fix was to go back and desolder the battery, clean it up with some flux, and solder it back. The center contact on the battery cable was not making a solid contact.
Score 4
4 Comments:
John, the re-soldering did the trick?
by
yep, it was the center connector on the battery.
by
Excellent. congratulations on a great fix....
by
@oldturkey03, I think I was a bit too late though. The iPod Home button is unresponsive and on power up goes straight to voice control. I noted this in another thread. I used a 30x loupe and noticed that right above where the center contact on the battery flex looks fried / smells burnt... I think the battery arced and nailed it. A sound reminder to me to put on that Kapton tape across the components above the solder pads. :(
by
Add a comment
hello my friend fast cheek battery OK be4 am Chang ok
1 Comment:
orignal battery ok
by
Add a comment
Add your answer
Country Computer Service will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 6,900
