Timer won't run through the cycle automatically but will manually?
The timer won't run through the cycle automatically but will if you do it manually
Hi Melissa,
The timer itself incorporates a small electric motor that's responsible for rotating the dial at a very slow rate, something on the order of 1/60th RPM, meaning it takes an hour to make a single rotation.
My son's washer died in exactly the same way; everything worked but the timer wouldn't advance. Taking it apart and powering the motor separately, I found that it wasn't turning at all. Unfortunately, on his washer the motor wasn't available separately so I had to replace the entire timer assembly when the problem was only the motor; I have no idea whether yours will be the same situation or not.
If you'd like specific information about replacement parts and/or repair instructions, we'd need to know the model number of your washer.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 64
