0
Score
johnaron
Asked
When I push the start button, nothing happens (most of the time).
The symptoms: Start-up fails. But a few times I'd get the start-up chime and then nothing. Once or twice I got to log in and then nothing. I noticed, before it died, that while typing and the screen wiggled, the screen contents also wiggled in sync. I took guidance from iFixit, using the "get the hard drive out" series. I needed to retrieve my photo library. Yah, Yah, I know, "why didn't you have it backed up?" I just didn't. I bought a DC-in assembly from you guys and in the meantime got a Universal Drive Adapter (Newertech) from OWC to get the stuff off my drive.
Yesterday I got everything back together, but got the same symptoms. 5 or 6 tries, maybe 1 or 2 chimes. This morning I tried again, got logged in, then nothing.
Does any of this ring any bells?
Thanks in advance.... J Aronson
I tried reseating my RAM to no avail, but thanks
machead3, rj713, and oldturkey03
4
Score
lemerise
16.2k
Answered
Accepted Answer
Looks like a failing graphic chip so the logic board would have to be replaced. No problem with your data, just remove the hard disk and put it in an IDE external enclosure or in another PPC machine.
there are a couple of forums with "fixes" for this issue including making a shim from foil to push the graphic's chip onto the board better. I also had this kind of issue with a bad start and it was the charger at fault (no screen wobbles though)
3
Score
pollytinto
34k
Answered
have you tried reseating your ram?
pollytintop,
I don't know how to answer responders
johnaron,
OK, now I get it. pollyintop, tx. No luck with the reseat.
johnaron,
pollyintop. tx...where to find the forums you mentioned?
johnaron,
lemerise... tx....is it possible to fix w/o $280 logic board?
johnaron,
You're kidding ? You can have one for $50 on ebay. Check for LaptopAid seller or click on this link: http://www.ebay.com/sch/i.html?_nkw=iboo...
lemerise,
lemerise...tx.. .all I find on eBay are "parts only"units. Any other sources?
johnaron,
Let us know what is exactly your ibook G3 14" model (processor speed).
lemerise,
lemerise....I'v e got the 700Mhz processor. iBook s/n UV2344BLQ3
johnaron,
I agree with you, not a big choice online right now for a used logic board for your ibook. Continue to visit the ebay link until one is available. Good luck.
lemerise,
You can "save" a search on eBay and get notified when something shows up.
mayer,
Show 6 more comments
