A digital camera manufactured by Canon Inc. released in september of 2010.
15 Questions View all
Camera won't turn on
My Canon (power shot sx20 )camera was stored (inside a walk-in closet with controlled temperatures) for a few, maybe 5 years, untouched. I went to use it and it won't turn on. So I replaced the 4 AA batteries and the small lithium battery inside the battery holding area. Still nothing. Does anyone have any ideas on what it could be?
Add a comment
1 Answer
Most Helpful Answer
Hi @chalke,
Were the original batteries OK inasmuch that they hadn't leaked?
If they had check that the battery connection terminals in the camera are clean and bright and not affected by any corrosion.
You could try cleaning them anyway using a Q-Tip lightly moistened (not dripping) with vinegar or better still if you have some 99%+ Isopropyl Alcohol.
It could be after all this time that there's a layer of verdigris on the contact surfaces preventing a good electrical connection.
Also double check that you inserted all the batteries the correct way ;-)
Score 1
Add a comment
Add your answer
Joan Hamer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 53
