0
Score
Avatar
tim
Asked
Able to use a 220volt PS3 here with 110volt?
History
I have a PS3 given to me while in France that is set up for 220 volts and want to play it here in the US. Is this possible? How do I make it able to run off of 110volts?
Do I need to switch out the power supply with a different one or is there an adapter that would work?
Edited by: rj713, osvaldo, Brian, and mayer ( )
Post Answer
3
Score
Avatar
oldturkey03
91.2k
Answered
Accepted Answer
PermalinkHistory
tim, you will not need to purchase anything but the power cable from the PS3 to the outlet. This only due to the different design of the outlets. The PS3 has a a dual voltage PSU 110/220. You do not require a transformer or any other device. You definitely will not need a transformer. Get the power cord from places like this. Plug and Play....:-) Good Luck
0
Score
Avatar
Mjvillanueva
Answered
PermalinkHistory
To work it on 110v AC source, you need to buy a step up transformer No need to replaced anything.
Edited by: ABCellars ( )
Mjvillanueva, why would you need this? The PS3 use a dual voltage PSU. Check on here http://www.ps3devwiki.com/index.php?titl... and bookmark this page for later reference.
oldturkey03,
Add Your Answer
