0
Score
Avatar
gregshear
Asked
Headphone jack output static in both channels
History
My iPhone 3GS headphone outputs static in both channels - I'm almost certain I fried the output amplifier. Will the replacement headphone jack fix this problem?
In other words, is there a new amplifier on the headphone jack assembly, or is the amplifier built into the main logic board and this headphone jack just connects to it?
Thank you!
Post Answer
Score
Avatar
Phillip Takahashi
24k
Answered
PermalinkHistory
The headphone jack assembly is just the ribbon cable; no ICs. You have tested to be sure that the issue is not your headphones are potentially a shorted or damaged cable correct?
Edited by: Phillip Takahashi ( )
I've tested with another pair of headphones, and I suspect i destroyed the output amp by connecting the phone to a questionable circuit (of my own design...) Is it possible to fix the output amp in the phone?
gregshear,
Unfortunately I would have to say no, not with the kind of gear the every day (or even above average) person would have at home. You would have to 1: find the correct chip that's damaged (it may be more than 1?), 2: find the exact replacement, and 3: have specialized re-balling equipment and techniques. You could try to replace the chip using just a heat gun...but I doubt you'd be able to be accurate enough with the heat or the chip to get a proper seat. Sorry I couldn't be of more help.
Phillip Takahashi,
Add Your Answer
