I can charge my phone but I can't connect otg to my phone it is not wo
I can't connect otg in my phone it is not working and showing on notification connect disconnected again and again even i remove it then also
Hi,
What type of USB device are you trying to connect to the phone?
If the USB device has a USB-C connector it should work.
If the USB device has a USB 2.0 connector you need to use a USB-C Male to USB 2.0 Type A Female OTG adapter for it to work.
You might need to enable usb debugging for it to connect. You shouldn’t have to.
To enable it go into settings then about device, find ‘build number’ then keep tapping it until it says ‘you are now a developer’.
Click back and go to developer options then scroll down to usb debugging and turn it on. Then try connecting otg again.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 121
