0
Score
Asked
ps3 still in ylod
hi i have a ps3 with ylod and i boght the reflow package from here so i follow the guide but the ps3 still giveme the yellow light i try to reflow for 25 secs like the guide says and then for a 1 min and nothing happen so i open it again and i try to reflow for like a 2 mins and still in the yellow light anyone can help thanks
2
Score
markus weiher
21.4k
Answered
do you have a crappy/dead motherboard to make a few test? if so, use that to determine the time/heat/ distance you would need to melt the solder. usse the dead board, point the heat gun on some smaller parts, watch the solder - when it looks more "shiny" - it should be molten (don't forget to keep an eye on the time it took to melt!) - then go to the next part - a bga ic - there should be a few on a common motherboad - make the same thing - but you won't see anything whats under the ic - but you should keep an eye on the surrounding parts (shiny!) - in case of a dead board - you could also try to "move" the ic a little bit (way less than a mm!!) - if the solder is molten - it should move slightly (don't try that on a board that should be repaired - it would most likely kill it) - same thing as before - keep an eye on the time! - now you sould be able to determine the heat an the time it would take to reflow the chip on the ps3.
i always use soldering flux for those kind of repair!
good luck
