iMac Black Screen & Loud Fans
iMac starts up with no chime. Also the fans start fine then after a minute or so go really fast. The screen also stays black.
The first two diagnostic LED light are lit. 3 & 4 stay off.
I can see no bulging or leaking capacitors.
Any ideas would be grateful.
Many thanks in advance,
Lewis.
Score -1
Add a comment
Most Helpful Answer
Led 1 means that the computer is receiving a source of power. When this is on the computer will be plugged in. LED two goes on when the computer has constant power and tries to boot up. Now here is the problem that you are having, LED 3 isn't on which suggests a video related issue. LED 3 means that video signal is being generated. If this LED isn't on then the computers graphics card has failed. This means that you can do one of two things. One, you can try a video card reflow(google it), or two, you just need a new logic board. The only sure way to fix this is with a new logic board. Sometimes the reflows will only work temporarily. Unfortunately this is the only thing that you can do because that is the only problem related to not having LED 3 on.
Hope this Helps.
Score 2
Add a comment
I had similar problem - turns out one of the 2 SIMM (RAM) cards wasn't fully inserted. When I corrected this, started up normally.
Add a comment
Add your answer
Lewis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 4,145
