Repair guides and support for your Sanyo TV.
360 Questions View all
TV won't register any ports at all. Channel 3 just Fuzz
I have a Sanyo DP26640. When I go to input all ports are checked but nothing I plug in to the TV will show on the screen except the old manual antenna. That picks up local stations just fine. I have a ROKU stick that was working plugged in to HDMI 1 but now I get nothing. Does the channel still have to be on 3? I tried a different ROKU that works elsewhere, I tried plugging in to different HDMI ports. Help!
Score 1
Add a comment
1 Answer
Ch 3 is only for things plugged into the ANT jack. Any port inputs like HDMI must be selected as an input. That is what the INPUT button on the remote does (sometimes labeled as something else). The fact that they are all checked on your setup only means that they are available as inputs, but you must select one. Hitting the channel button usually reverts the input to ANT. The Roku I have will cause the TV to change to the HDMI input if I hit any button on the Roku remote. Not all do that so you must change the input to the HDMI port the Roku is connected to.
Add a comment
Add your answer
Pamela Haymond will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 197
