0
Score
Avatar
Jeff
25
Asked
Wire from airport antenna broke off from connector
History
I'm replacing the screen on a G4 powerbook. While disassembling the unit to remove the display I inadvertantly broke the airport antenna cable right at the connector when I tried to disconnect it, consequently the connector is now rendered useless.
My question/s is/are: Can I use a small butt connector to reconnect the airport antenna cable to the airport card cable or do I need to use the exact same type of brass connector?
If I do indeed have to use the same connector, where might I find one?
An answer to one and/or both of these questions would be most appreciated.
TIA....Jeff
Post Answer
Score
Avatar
rj713
33.9k
Answered
PermalinkHistory
Hello Jeff, The way I would go is to buy a replacement cable for a complete and trouble free repair. Link provided. Good luck.
G4 Aluminum 15" 1/1.25/1.33/1.5 GHz Inverter & Antenna...
Product Image
Inverter and Airport/Bluetooth antenna cables — 19 available at 24.95 each.
Thanks rj....Yeah I was looking at this earlier and actually added to my cart but I wasn't sure whether or not the antenna cable had the connector attached to it as the picture is somewhat indistinguishable. So I guess I'll just go ahead and order it....Cheers
Jeff,
Add Your Answer
