Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
474 Questions View all
Why doesn't my phone charge right?
My phone doesn’t get a good charge. It has to be in the perfect position for it to work. I have tried different cords to charge it with, different bricks, everything. If I use my phone while I am trying to charge it, it constantly switches between charging and not. If I don’t place my phone in the correct spot when I go to bed, it will be like halfway charged in the morning. I tried cleaning the charging port out but that did not work. I’m not sure if I didn’t clean it well enough or if the problem is something else. Help?
Score 1
1 Comment
Have you tried to charge the phone with other cables?
by
Add a comment
Chosen Solution
Does the cable actually sit flush with the bottom of the phone? If not, there’s still debris in the port. Generally my advice for cleaning the port is, get something thin, sturdy and non conductive. Toothpick works well enough. Use a flashlight to check and see what may be in there, sometimes it’s hard to know what it’s supposed to look like. But usually you can tell if there’s lint or other debris in it. Aim straight for the back of the port. Usually that’s where stuff is going to collect since it’s picking it up from a pocket or what have you and getting compressed into the back of the port when you plug a charger in.
If cleaning still doesn’t work, sounds like you’re in the market for a new charge port/dock flex assembly.
Score 4
Add a comment
Look in the lightning port and clean it out gently with a toothpick.
Score 2
Add a comment
The Apple store will clean out your lightning port for you; they have a custom tool to do that. Also, they use an endoscope to look for the lint.
Hint to Ifixit folks - I’d love to have a tool that cleaned out lightning ports.
Add a comment
Add your answer
Morgan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 126
