0
Score
QEII Student IT
3.5k
Asked
Internet connection through Ubuntu?
I have recently installed Ubuntu to my newly partitioned hard drive, on the other partition is Mac OS X. In Mac OS X, I can use Safari, Firefox or Opera to browse the web. In Ubuntu, my only browser at present is Firefox. I am unable to connect to the internet, I have tried some Network settings but I have never used Linux before. How do I connect to the internet?
2
Score
stacywebb
125
Answered
Accepted Answer
If you prefer a graphical interface and depending if you are using Gnome or KDE this will help you.
http://www.ubuntugeek.com/ubuntu-networking-configuration-using-graphical-tool.html
2
Score
Sarabian
125
Answered
If you have a router, or one of the newer DSL modems - do NOT try connecting using PPPoE directly from the computer. You will then be logging in when you are already logged in. The router or DSL modem should handle the PPPoE connection, not your computer.
As to why you might not be connecting to the internet from the Linux side, try entering in terminal "ifconfig" and make sure you are getting an IP address. You might even try setting a static IP address and see if that helps the situation.
Some (older) home routers can't deal with a computer restarting into another OS. It sees the mac address as the same, but for some reason doesn't like the different OS. Restarting the router seems to help on these. I have seen it mainly on old Linksys routers.
Score
rj713
31k
Answered
Hi, You might take a look at this URL. Ralph
http://www.ubuntugeek.com/ubuntu-networking-configuration-using-command-line.html
Score
jimmyhchan
197
Answered
The internet should "just work". Try powering the computer on with the ethernet cable plugged in.
Open up a terminal (Applications>A
type the command "dmesg" which outputs information about the boot process. Look for errors here.
Lastly, congratulations for trying Linux but more importantly welcome to the Linux community! Don't be shy. Hop on irc and ask around http://www.ubuntu.com/support/community/... http://www.ubuntu.com/support/CommunityS.... There may also be a Linux User Group (LUG) in your area.
Score
Anky
109
Answered
Use the Ubuntu Help, it's on the taskbar, I think. The option for connecting to internet should be there.
I'd tell you the method, but I don't know the type of connection you have.
If you've got a PPPOE Ethernet based ADSL, you open Terminal [Applications>A
And yeah, make sure you add sudo before every command.
What happens when you open up Firefox?
rab777hp,
This question may be better asked on some linux forums. In fact, http://www.linuxforums.org/ is a fantastic resource.
Kyle Wiens,
When I open firefox it says it can't find the webpage
QEII Student IT,
