Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Questions View all
Tablet won't turn on
Whenever I try to turn on the device it just blinks the notification light 3 times. I’ve tried charging it but no luck. Can someone help?
Update (12/03/2021)
Figured it out. For one it was 5 blinks, not 3, and also you just need to charge it longer it seems. I recommend
90 minutes - 2 hours.
Add a comment
1 Answer
I would recommend you try a different cable and/or wall wort charger that is a 2a rated one. but it is most likely a cable issue. some use 2 paths of power to charge and if one path is damaged you get slow/no charging.
Add a comment
Add your answer
Jack Swallowell will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 10
All Time: 68
