0
Score
Avatar
Maliklbw
11
Asked
Dropped iPhone and now has blank screen ...?
History
I dropped my iPhone and now has black screen. display not showing, phone still working, calls coming, and I feel touch system also not working.
What should I do?
Edited by: oldturkey03 ( ) , okivia ( ) , Maliklbw ( )
Post Answer
2
Score
Avatar
Brad
8.4k
Answered
Accepted Answer
PermalinkHistory
Reset, Hold both Home and Power buttons until the White Apple shows, usually about 15 seconds time. If that does not work, possibly the Screen Flex Connectors #1, #2 came loose from the Logic Board. If you can turn OFF iPhone, hold both buttons again for about 3-4 seconds, then release them, see if vibrate works if not, hopefully it is OFF. Carefully open iPhone and check to be certain both connectors are properly seated.
Okay! Thank you. I restart, on off, but it seems to be connectors problem. I should go to service center.
Maliklbw,
0
Score
Avatar
Onur
Answered
PermalinkHistory
Also check your iphone's screen under bright light. If your backlight IC damaged you still can see everything but in a lightless way..
No seen anything, it is blank! thats Connectors problems
Maliklbw,
Add Your Answer
