Where is the left palm rest temp sensor?
I have a MBP 13" 2010 that suffers from a faulty and very temperamental temperature sensor. When the bottom case rests flat on a table, or any surface for that matter, it causes the sensor to register a nonsensical temp of -128C, the fans to kick into overdrive, and kernal_task to consume 180% of CPU. Simply pressing on the bottom case around the general location of the RAM also will reproduce the same effect.
According to Bresink's Temperature Monitor the sensor at fault is the "left palm rest" sensor. Where is this sensor specifically? Is it on the top / bottom of the logic board? Integrated into the top case? Any info about this sensor would be greatly appreciated.
Thank you in advance.
10 months on now and am still in need of help.
8 Comments
bump, anyone? Any ideas?
by Ouroboros
Still in need of info for MBP 13" 2010 temperature sensor locations. Any help would be greatly appreciated!
by Ouroboros
i have the same problem
by jwills1
did you find out where it is???
i have a few ideas reply we will fix this out!!!
by jwills1
No, I unfortunately still haven't.
by Ouroboros
Show 3 more comments
