0
Score
Eric
11
Asked
Doesn't launch Windows, say Hard Drive defective
Few weeks ago, my dell laptop starts having problems with the hard drive. For example, when I saved something on it, if I want to read it few days later it couldn't.
Today, It doesn't even start, it goes to windows recovery and signals that the hard drive is defective. If I boot from the CD I can't reinstall windows. I'm trying to format it doing format c: but it's still at 0% since 40min.
What can I do ?
Thanks
Score
oldturkey0
87.9k
Answered
Accepted Answer
It looks more and more like you have a hard drive that is failing. You might try to access it with any of the Live CD Linux disks that are out there. Ultimately, I think your best bet would be to replace it. You will also need the need to use Dell recovery disc to restore your computer. If the recovery disc did not come with your computer than Dell generally provides it for free. You can call their customer service in Sales at 1-800-999-3355 The hard drive is available at multiple places like this and here is a decent video that can help you with the task. Good Luck.
Edited by: oldturkey03 ( )
Thanks a lot. But do I need to buy the original HDD ? Is it possible to buy another one ? I mean, what specs do I have to take into consideration if it is possible ? I don't have the recovery CD, what if I try to install W7 on a blank HHD ?
Eric,
You would be okay with any 200 or 320GB2 5400 RPM SATA II hard drive. Your biggest challenge will be installing W7 since you will have to find the drivers. Dell considers the XPS M1530 obsolete and will not publish 64-bit drivers but you may check here http://keyliner.blogspot.com/2009/10/del... for what you need. Hope this helps.
Does it still show up in the BIOS?
oldturkey03,
if you mean when I press F12, yes
Eric,
but is does not format and you can not reboot? Have you tried a Live CD like Puppy Linux (my favorite) or any other of the Live CD to see if they can access your drive? It does sound like you have a bad HDD
oldturkey03,
when I try to reinstall Windows it refuses and says "your hard drive is going to fail"
Eric,
no formatting fail too...
Eric,
I don't have any CD right know and I can't boot it from a USB stick because it needs to be installed first. But I doubt it would boot nothing seems to be able to access the Hard Disc...
Eric,
Show 1 more comment
