2
Score
Tsutomu Niimi
405
Asked
The Brown connector broken.
The brown connector break one of the arms. I still have it, what should i to do fix battery cable?
Update
Dear Mr.Oldturkey03.
I have to say a lot of thanks for your advice,
and knowledge. "arigatougozaim
I try to daiagnostic my iPod, then I look up a funny incident.
My iPod has only 30GB, But diag says 289GB!
I will tray to change HDD, and restore.
I am very exicite that your kindly answers.
I like MAC and iPod.
Please help me !
Edited by: mayer, rj713, and Mike ( ) , Tsutomu Niimi ( ) , oldturkey03 ( )
6
Score
oldturkey0
91.2k
Answered
Accepted Answer
Tsutomu Niimi, if the connector broke of the logic board, there are only two solutions. One is to get another connector from an old logic board and have somebody knowledgeable with SMD components solder it on. The only other way is to replace the logic board. UPDATE
If the brown part is off the white part, you can try and replace the clip with an old one from a spare board. If the white one is off the board with the pins sticking out, you can try and slide the white plastic back over it and use some glue to glue the plastic onto the board. If the pins are bend or dislodged you will have to get a new one soldered onto the board.
Edited by: iRobot ( ) , oldturkey03 ( )
Thank you, Mr.oldturkey03. I tryed to push brown connector, and it seemed to be sucessful. Battery cable was fixed comletely!!!!! I started up the iPod and the apple logo appeared!! Shortly after, a screen saying "Connect to your Computer. Use iTunes to Restore." in about 5 different languages. I connected it to my computer, then a message in iTunes showed up saying "iTunes has detected an iPod in recovery mode. You must restore this iPod before it can be used with iTunes." I then clicked Restore and entered in my Administrator name and password. Shortly after that, an alert popped up saying "The iPod "iPod" could not be restored. An unknown error occurred (1416)." What happend?????
It is possible that you are having further logic board issues and/or hard drive issues. What happened to the iPod before you changed the battery? I think the 1416 error is an initialize error. I would try to either put the ipod in diagnostic mode and see what it tells you, or run it in disk mode and see if you can access the HDD and definitely try to save all your files. Hold down the menu and the center button until the apple sign appears, then as soon as quickly as you can hold the center button and the play button down. When the disk symbol shows up in the middle of the ipod, hook it up to your computer. you are now in disk mode and see if you can access the drive. Try to reformat but remember that you will lose your files. Good Luck
0
Score
Raiz
31
Answered
0
Score
Answered
Hey I don't know if you still need an answer but i've managed to fix my Ipod Video with the same problem. I did it the cheap way and with Super Glue!
Basically I broke the retention clip off the LCD connector which is on the logic board.
I found that I needed the LCD display to be on in order for Itunes to successfully detect my IPOD, and use it (obviously).
Because the retention clip is missing, it means you can push the ribbon cable all the way "through" the connector and it won't get contact with the pins on the logic board, this is why with mine when you push the ribbon half way into the connector it'll light up, but then when you push it all the way through it goes black again.
What I did was, and it's incredibly easy, is push the ribbon cable into the connector with the missing retention clip, hold it in place so the screen lights up, and applied superglue to the connector and edges of the cable, and it worked fine. I did this while my ipod was on and connected to a computer. I didn't really care if I stuffed my ipod completely though.
Can post photos showing it going/ with the cover off and missing retention clip if needed.
Will, I've had the same retention clip problem with the hard drive . I would love to view a picture of the solution you used.
Hey Rick, My Ipod died yesterday, I re-opened it and found the Super Glue I had used pretty much melted part of the ribbon cable and stripped away some of the small semi-conductor type things on the Ipod. In Hindsight what I would have done, and to be honest have no idea why I didn't, is use a hot glue gun to keep the Ribbon cable on the Logic board and the pins aligned with the connector. You would probably have to do this while the ipod was on and showing the GUI screen (where you pick your songs etc..) as what you might find it you glue it in place, turn it on, and have the White screen of death
0
Score
Tsutomu Niimi
405
Answered
The conclusion of a solution for battery cable problems
1)Only the brown connecter was broken
You should order a new part this site, and reinstall it.
http://www.parts4ipods.com/epages/es1157...
Then it could be OK, and your iPod would be resumed.
2)Serious situation
When a white part have been removed from the logicboard.
(Very serious problem, no adhesive can help this problem.)
A situation is told to below by e-mail or Fax, and you send parts, and have you solder to a logicboard again.
E-mail:webmaster@
Mr.Masaharu Nose(CEO)
Address
"Nose-seiki co.Ltd."
271, Ohhagi-Town Higashiohmi-City Shiga-Pref. Japan
Postal code 527-0174
Tel:81-749-29-0989
Fax:81-749-46-1133
Also I introduce this company homepage and weblog.
"Re-soldering of the connector which has taken the ipod board"
http://www.soldering-guide.com/archives/...
http://www.noseseiki.com/drhanda/patan.h...
Sorry, although it is a Japanese site, but I think that it turns out that I introduce if you have a photograph and movie seen.
I think that there is no company which has the technology so far in the world as far as I get to know.
Do not give up, Good luck and God bless you.
Hey, I found an Ennglish version. http://www.soldering.jp/ Do not give up and God bless you!
Thank you Mr.Oldturkey03. Broken part is only plastic brown connector arm. Logic board is not broken.
Tsutomu Niimi,
I understand but the connector is what connects the battery cable to the logic board. What ipod is it?
oldturkey03,
Dear.Mr.Oldturk y03. My IPod is iPod video(5th) 30GB.
Tsutomu Niimi,
Thank you Mr. Oldturkey03. The picture is same as my iPod. And white parts has not damaged. Only brown part is broken. I pulled battery cable and brown part was also removed. It has 2 arms to fix the white part, and one arm is failed. I try to new battery and to reinstall. I am very happy your kindally answer, and thank you itFix it! As far as I am in Japan, but I am very happy to use Apple's iPod!
Tsutomu Niimi,
If it breaks put the cable in the slot and then push the brown holder in place to keep the cable from slipping out. Is it the best way to solve this incident??
Tsutomu Niimi,
Tsutomu Niimi, yes it is. I have not been able to fix it any other way.
oldturkey03,
Place your iPod in disk mode and reformat it. See what it will tell you about the size of it when you format.
oldturkey03,
Dear Mr.Oldturkey03; I can boot my iPod at disk mode, but connect to my Mac, it cannot be mounted at desktop. Also it not sees at disk utility, so I cannot be reformat. Is there a way to reformat at iPod who is stand alone?
Tsutomu Niimi,
Tsutomu Niimi, this leads me to believe that your hard disk is not working. The only way to format it is be having it in disk mode, or recognized by itunes. You can purchase a Zif-to-USB connector to plug your HDD in with the iPod.
oldturkey03,
Dear, Mr.oldturkey03. I bought a new HDD(HITACHI), and set up may iPod but I could not reformat. As same as ZIF-HDD, but in hear shop's inform Toshiba and HITACHI are not compatible to connect iPod. Now I use a cabel for TOSHIBA, have I to buy a cable for HITACHI? I try to connect PC, but I cannot reformat. iPod Diag says my new HDD has 96GB!
Tsutomu Niimi,
Tsutomu Niimi, yes that is correct. As a minimum you will have to use the Hitachi cable, the Toshiba is NOT compatible. Good Luck.
oldturkey03,
Thank you for all persons. My iPod is now completely works, many thanks! But, only one problem is happend. No click sound for my iPod. Try to Diag mode at my iPod, but no beep sound. Where the sound come from and how can I solve this problem?
Tsutomu Niimi,
Tsutomu Niimi, Good job in getting it fixed. If everything works the way it should, but you do not get the sound when you use your wheel go to Settings>Clicke r> and select the ON and honestly I am not sure at what part in the diagnostic mode you get a beep sound :-)
oldturkey03,
Dear all; I found the connector as belows. http://www.parts4ipods.com/epages/es1157... Only brown piece was broken, so I bought the connector and remove a brown piece from it, and install on a Logicboard. Then this issue was compeletely solved. Thank you for many advices!!!
Tsutomu Niimi,
Tsutomu Niimi, great job. You will find that even so you have your device repaired, you will still get lots of advice after. Lots of people know of different ways in accomplishing the task :-). Good Luck to you.
oldturkey03,
Show 10 more comments
