The Krups Espresso Mini is a steam powered espresso machine made for household use.
7 Questions View all
How do I fix my coffee pot? put water in, it won't come out in pot?
Device not present in your list - I have Type 867 Krups Cafe coffee and espresso maker. 22yrs old! the espresso works fine. When i put water in the pot, it just wont work when i turn it on, water stays in reservoir, bottom where pot sits never heats up either. I really want to keep and not replace!! Please help!
Add a comment
Most Helpful Answer
@needscaffiene since “water stays in reservoir, bottom where pot sits never heats up either” I’d be looking at the heating element for the coffee maker (not the boiler for the espresso) as well as the fuses and thermostat for the coffeemaker. Since it does not heat the water nor heats the warming plate the issue here seems to be a power issue to the heater. You’ll have to try and disassemble the Krups and check things out. It will always help if you can post some pictures of what you find while you do the disassembly. We might get a more concrete idea once we see what things are looking at.
You can post images with your QUESTION by following these instructions Adding images to an existing question
Score 1
Add a comment
maybe theres a coffee seasoning stuck on ur coffee machine been not out the water thats why the coffee seasoning it will not out on ur coffee machine grabs some towel and clean the coffee seasoning on your coffee machine and add some coffee and put water in it will be works!
Add a comment
Add your answer
Lois Dawes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 409
