Repair guides and support for the random-access memory used in computers.
45 Questions View all
Why won't my laptop boot up?
I have an Acer Aspire 5742 laptop and I’ve just added an extra 4GB of RAM to give me a mighty 8GB in total! I have re-seated the RAM chips a couple of times now and I’m pretty confident I have seated them both correctly. When I press the Power On button, the screen shows the initial acer ‘splash’ screen with the instruction, “Press <2> to enter Setup.” There is brief sound of the hard drive coming to life then the machine powers down. It then restarts in a continual loop of this activity until I remove the battery and mains power supply.
I have pressed <F2> and get 4 (four) quick, short beeps before the machine powers down.
Any suggestions as to what I am doing wrong or need to do next please.
Add a comment
Chosen Solution
Sorted it with a new battery!
Score 1
Add a comment
When you upgrade RAM on any computer, not just laptop, the first time that you turn the computer on, it may display some information about a change that you just made to the configuration. This is normal behavior, it just means that your computer is adjusting to a change that you made to the hardware of the computer and, because of that, it is essentially updating the configuration to allow the extra 4GB memory module that you installed to take effect and give the boost that you wanted. It is normal for your computer to restart continously after you installed the RAM. The thing that you did wrong was unplugging the battery while the computer was on. You didn’t make your computer faulty as a result of that. Reboot your computer, with the newly installed memory module, and do not touch anything and let it boot up and do that loop that you mentioned. If that turns out to not be a solution to your concern, please tell me more.
Add a comment
I would try holding the power button for at least 15 seconds, then turning it on as normal. Hope this helps!
Add a comment
Add your answer
Stuart Adams will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 131
