solder pads on iPod Touch 3g battery replacement
So I was replacing a battery on my Itouch 3G and unfortunately I did not have the middle solder pad heated up enough and it pull out from the logic board and is still attached to the battery. Am I screwed here, I would greatly appreciate any ideas I was thinking to try and pull it off the battery and solder it back on the board is this possible? or if I could not get the original pad off the battery could I cut out one of the solder pads from the old battery and use that on the logic board for a solder pad. Thank You.
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by iRobot
