0
Score
Joe
11
Asked
No Wifi with closed lid
MacBook Pro 15" 2.16GHz Core Duo Model A1150
I mostly use my MBP in "closed-lid mode" and connected to an external monitor. The problem is the 802.11 signals cuts out when the lid is fully shut. Not completely, but it's either sporadic or "trickles", because a web page will take about 5 mins to load. Therefore, I have to open the lid a few inches to be able to use wifi. It sucks. Another possibly related problem is that the hinge is loose.
Bluetooth signal quality always sucked, but I've learned to live with it. I like my Mac, but shame on Apple for the expensive power supplies with connectors that break so easily.
5
Score
mayer
121.8k
Answered
Accepted Answer
Replace your antennae cable: MacBook Pro 15" (Model A1150) Airport Antenna Cables
Antenna cables and the assembly that rests inside the antenna cover. — 2 available at 29.95 each.
Thanks Mayer. Hopefully I can find one up here in Canada. Any idea how they fail? I've got the antenna module in my hand but I don't see any damage at all. The corner contact on the Airport board which appears to connect the shield to the MBP chassis looks quite oxidized though.
Joe,
It worked! I ordered an antenna assembly from powerbookmedic.
Joe,
