The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 Questions View all
2DS won't charge and shows no charging light
Hello! I bought a 10€ 2DS just for fun but it doesn't charge the battery.
What I've checked so far:
  • Battery (ok. Charged externally, holds it's charge and powers the system just fine)
  • Charger (5V ok)
  • Charging port and fuses
  • With the 2DS opened up and the charger attached it doesn't start. The yellow charging indicator doesn't light up at all. I have the 5V off the charger on fuses F1 and F2, before and behind the voltage filter and even on the battery pins.
I think the charging IC is shot. Or are there other things to check? Maybe it's an easy fix.
Add a comment
Hello,
Go to this website if you charging port is not working but the cable is fine: Nintendo 2DS Motherboard Replacement
if the port is fine but the cable is not you may just have to buy a new cable
Add a comment
The port and the charging cable are okay since I checked the voltages on both of them.
Add a comment
Did you fix this after?
Add a comment
Add your answer
Thomas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 17
All Time: 378
