0
Score
Avatar
Kyle
Asked
I want to fix a water damaged mac.
History
This is a hypothetical problem for a still learning mac repairman.
There are a lot of forums and help sites saying turn power off, dry out mac and cross your fingers. This forum is different.
Water damage is already done.
I know to clean off the connections on my ram with rubbing alcohol. But if that does not fix the problem, how do I go about fixing the water damaged parts?
Short of replacing the logicboard (assuming that was what was damaged) what can I do to fix the mac.
-What are the most commonly damaged parts when water is spilled? and how would you fix them?
-If the logic board was damaged. What exactly happens when water hits the logicboard and it "fries". Like what physical damage is caused and how can I reverse it?
I am skilled at saudering and not scared to go into the thick of the parts to fix the problem. I just dont know where to start finding the short.
Thank you for any hints, tips, suggestions, anything.
Post Answer
3
Score
Avatar
mayer
148.1k
Answered
PermalinkHistory
Here's our guide on repairing liquid dMAGE: http://www.ifixit.com/Wiki/Electronics_W...
Without replacement parts it's very hard to say what may or may not need to be replaced. If you have one of the newer machines with LSI (liquid submersion indicators) just follow the red dots to get an idea of what may be damaged.
Score
Avatar
pollytintop
39k
Answered
PermalinkHistory
I don't think that water hits the logicboard and fries it every single time. I have repaired iphones/toys with water damage just with repeated cleaning with isopropyl alcohol and a soft brush (girly eyemake-up brush) the parts that most needed replacing were connectors..the water tends to pool in the logicboard side. I know I'm answering about a macbook, but I think the principle is the same..clean your board,dry-assess residue,clean again, and again and again. Remove any white or greenish residue from around ALL the parts. Leave to dry. use a new/known good power source to restart...hopefully you'll then be able to troubleshoot. As Mayer says follow the trail..if the liquid came in through the keyboard then it probably ran off at the edges/through holes in the keyboard, check the areas under that. A good multimeter for testing parts helps.
Score
Avatar
kefavret
13
Answered
PermalinkHistory
It could be anything. After using ifixit to disassemble my whole mac one cable after another after my toddler dumped a full glass of water on the keyboard, it finally ended up needing a new battery and leaving the cable for the external battery indicator lights disconnected... that was what shorted! With it connected no recognition of battery even existing. Disconnected, the battery charges and operates perfectly. I'll live without the lights...
0
Score
Avatar
johsua
Answered
PermalinkHistory
geta a good quality keybord foo! this isn't a scam. get a *@%! keybord
Add Your Answer
