0
Score
Avatar
Rod
11
Asked
Requesting more specitivity on guide for installing RAM
History
First of all, I love this site and the guidance is amazing. But for someone not used to working on electronic devices, I'm a little hesitant to start sliding in computer boards/chips if I'm not exactly sure where to do it.
In reading the the guide for installing RAM in my Macbook Core 2 Duo, everything is very specific until the end where it doesn't really show exactly where the RAM is inserted.
Can anyone expand on that because when pulling back on the metal lever, my fingers are not small enough to slide the RAM chip out and I don't want to force the lever too much...
Any help would be greatly appreciated...Thank you!
Edited by
Post Answer
3
Score
Avatar
rab777hp
12.6k
Answered
Accepted Answer
PermalinkHistory
Changing the RAM on this machine is perhaps the simplest repair you will ever do- don't worry at all. The ram is in those two slots you can see in the guide pictures, you won't run into any problems "forcing" the lever, it's very straightforward and all comes out easily.
Thank you for the vote of confidence! But when I pull on the metal lever, is the old chip suppose to "pop" out, because otherwise it seems pretty difficult to grab with my fingers...
Rod,
It'll come out pretty easily, I doubt you'll have a problem unless your fingers are the size of soda cans.
rab777hp,
Never should have second guessed you guys or myself. It was quick and easy as you said even with my stumpy fingers... Many thanks again.
Rod,
If this answer solved your problem, please accept it so it can be archived for others, Thanks
mayer,
Add Your Answer
