Score
Avatar
jenny
13
Asked
My iPod fell and the screen turned white, why?
History
I dropped my ipod and when i picked it up to look at it i couldnt see the screen it was just white and ive tried everything what can i do??
The white screen is really just your backlight working. You said you tried everything. Not quite sure what everything entails but try to "Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears." Also see if you can place it in DFU, follow this http://www.youtube.com/watch?feature=pla... video. You did not mention if itunes or your computer still recognize your iPod. My guess would be,no.
oldturkey03,
Post Answer
Score
Avatar
Max
403
Answered
PermalinkHistory
The LCD connector on those is taped down with copper tape so I do not believe it came loose. Does it still make any noise when you plug it in or lock and unlock it? Chances are you need a new LCD/Digitizer assembly. This is a tricky one to replace and I recommend seeking professional help if you are not experienced with this sort of thing.
0
Score
Avatar
Jon
55
Answered
PermalinkHistory
Either your LCD connector came loose or your LCD/Digi ASSY needs to be replaced. I suggest pushing really hard on the top/mid-right portion of the screen and then performing a hard reset using the Sleep and home buttons.
Edited by: Jon ( )
0
Score
Avatar
frank
Answered
PermalinkHistory
If a hard reset or putting it in dfu mode does not work.....White screen either is a bad lcd or a bad logic board. I have seen allot of bad logic boards in the 2nd and 3rd gens.
0
Score
Avatar
connor roach
Answered
PermalinkHistory
if you have dropped it in water which i did leave it on a radiator for a while it seems to fix it well this worked for me anyways :)
0
Score
Avatar
Juli Oda
Answered
PermalinkHistory
Hi! I had the same problem, my iPod fell on the floor and the screen is white as i turn it on.
iTunes recognizes it, it makes sounds as I unlock the screen. Tried to restore it, but nothing changed...
I´ll try the suggestions above.
Tks.
Edited by: Juli Oda ( )
0
Score
Avatar
Juli Oda
Answered
PermalinkHistory
Hi!
I tried the two suggestions above and they didn't work....
Does someone have any idea what might be the problem?
It works fine with iTunes and does unlock, but the screen is white with a gray stripe on the side...
Thanks for any help!
0
Score
Avatar
Craig
615
Answered
PermalinkHistory
Sounds like the connection is bad or the lcd was damaged during drop.
0
Score
Avatar
pooie
Answered
PermalinkHistory
Butter Face.
0
Score
Avatar
fryarludwig
231
Answered
PermalinkHistory
If you would feel comfortable following the steps in this guide right here then go for it, it's almost guaranteed to solve your problem.
Installing iPod Touch 4th Generation Front Panel Replacement
If you want to go ahead with it you can find your part on eBay here:
http://www.ebay.com/itm/LCD-Touch-screen...
if you have a black one. If you have a white one,
http://www.ebay.com/itm/270945846612?ssP...
Best of luck. It's not as hard as some people say. Just be careful and steady, don't push or pull too hard, and use common sense.
Edited by: fryarludwig ( )
Shipping takes 2-4 weeks if you get it from China. If you get it from the US your shipping time will be 2-14 days, but it'll cost more.
fryarludwig,
Add Your Answer
