0
Score
Avatar
bobby
Asked
iPhone got wet and now screen is very dim.
History
My iphone got wet in a washing machine and than it was working properly. but suddenly its screen become very dim. I can see only under bright light.
can anyone help me to fix this problem
Post Answer
0
Score
Avatar
Matt Barnes
7k
Answered
PermalinkHistory
Have you thoroughly dried out your iPhone? If not, then you may want to use the Thirsty Bag to get all the moisture out of your iPhone.
If you still have the same problem after drying, then you probably need to replace the display or the logic board.
Product Image
iPhone 3GS Display
LCD panel / Does not include touch portion of display or the metal backing plate. — 6 available at 69.95 each.
Product Image
Thirsty Bag
Drying bag for liquid damaged electronics. — 50+ available at 9.95 each.
0
Score
Avatar
oldturkey03
88.6k
Answered
PermalinkHistory
I am not sure about replacing the display or the logic board, that's like using the big guns right away. If you are handy, try to replace the coil on the logic board first. A lot cheaper...you can get the 6R8 coil on eBay and many other places or from here and if you are wondering how to do it, you can watch a video.
Score
Avatar
Ash
131
Answered
PermalinkHistory
Old Turkey is spot on here.
First call would be the 6r8 coil.
If still dim then I would replace the screen but more than likely it will be the 6r8.
Dont replace the logic board until all esle has failed.
Its expensive and usually un-necessary!
Add Your Answer
