0
Score
ddelmonte
67
Asked
Fans are on a lot.
When my MBP is idling, the fans go to full speed (6000 rpm) after 5-10 minutes.
As soon as I start using the system, the fans calm down to normal (2000 rpm).
I have reinstalled the system, and tried different systems (Tiger, Leopard, SL).
Any ideas?
Thanks in advance.
David
2
Score
mfdavidson
25
Answered
I have had my fans go on more than I like as well and my MacBook Pro runs hotter than I like at times. Since it has been thoroughly vetted by Apple, I have found using "smcFanControl" has solved the issue for me. It allows me to have the fan at slightly higher speeds and hence it never get as hot and hence the fans don't start racing.
2
Score
Bruce Corson
121
Answered
The Apple Certified Tech's answer above is a good one, and maybe the correct one. An additional solution for me has been to download SMC Fan Control, a free add-on that will allow you to manually (or automatically) control the fan speed, and in additional will show you the temperature in your laptop.
Score
irywitham
13
Answered
In my experience as an Apple Certified Tech. this is usually due to SMC firmware needing to be upgraded. You can go to the following link and download the update: http://support.apple.com/kb/DL350
Score
David Iwanicki
2.7k
Answered
Score
cshyde
13
Answered
This problem occurs with a lot of notebooks. The cooling module attached to the processor gets clogged with fine dust and lint. The processor heats up quicker and the system turns the fans on high speed a lot more often and for a longer period of time. You should open up the computer and blow it out from the inside back through the air outlet. Otherwise you will be blowing the dust back into the computer. If it is clogged you will get a pretty big cloud of dust so do it somewhere where you wont get yelled at.
0
Score
Chris Green
13.6k
Answered
you might want to look into a program called "Chud Tools" they include somthing called "Nap" mode, in earlier operating systems. in snow leopard, or leopard, and tiger, there should be the option to turn on nap mode already there under the "hardware" tab in system preferences, then simpily, turn it on, this should resolve the fan issue. Noise was a big problem in late model powermac g4's and the CHUD tools were a lifesaver to people whose g4's were ridiculously loud.
0
Score
glenhandy
49
Answered
It usually means that your computer is running too hot. I have found most laptop do not cool adequately and need extra cooling. I suggest that you buy an external Fan that is made to sit under your laptop and plugs into the USB.
This is cheaper than a new laptop, as the extreame heat will cause the processor to fail.
0
Score
Answered
This happened to my MacBook when I first got it and migrated from my old MacBook. After putting up with the fan for a while, I opened up Activity Monitor and discovered an old startup item that was going out of control. Deleting that calmed things down. I usually look for a software cause before assuming hardware is the culprit.
