0
Score
michael
Asked
iPhone 4 cant find wifi hotspots
hello,
have here iphone 4 after lcd replacement cant find any wifi signal.
have solution for this?
Score
pollytinto
39.3k
Answered
Installing iPhone 4 Front Glass Display Assembly take a look at step 14...clearly states the reason for most loss of wifi signal after repairs..check your screws are in right (step 13 has a good tip) the clips are on the metal cover etc. That 4.8mm screw is important and so is the area that holds it in, take a good look for any damage there. You also need to make sure you have cleaned greasy fingerprints off your metal work.
0
Score
Answered
Sounds like the phone was assembled incorrectly after repair. One of the cable under the screen is possibly not connected properly
0
Score
Answered
I got problem long time with iphone , not finding wifi signals it not was to close to the router!!
checkthe photo of that piece and see if you have lost the metall piece fromthat,, if so find it or replace and u will get back wifi.
0
Score
dkcengizbo
79
Answered
0
Score
Answered
Reply to:
A piece of aluminum can do the trick too :) just fold aluminum so it is approx. 8mm x 4mm x 1-1.5mm and place it under the screw and the round gold/metal piece right next to the screw.
Can you provide a picture? Does this completely repair your WIFI signal?
I posted http://www.ifixit.com/Answers/View/10943...
In one important post above it says, "That 4.8mm screw is important and so is the area that holds it in." I think I lost part of the "area that holds it in" and am now getting no WIFI signal.
