Score
Avatar
Tao
23
Asked
Start-up Issues related to Battery
History
1. MBP will start-up with battery removed and will shut-down normally and start-up normally
2. If the charged battery is first installed, the MBP will start normally. Upon normal shutdown, the MBP will not start-up (no response).
3. The magsafe cable shows a green light.
4. The battery indicator shows charging and will come up to 99% charge.
5. New battery did not solve the problem.
6. Removed the battery and performed the >10 second reset. No improvement.
Edited by
AHT indicates all OK.
Tao,
Post Answer
0
Score
Avatar
Scott Head
5.4k
Answered
Accepted Answer
PermalinkHistory
I would at least try to do run Apple Hardware Test (AHT) and see if that reports any sort of error that might help you determine the problem.
AHT is on one of the restore discs that came with your computer.
Add Your Answer
