Score
Rowan Wookey
13
Asked
Can I upgrade my airport to a N model?
I've a mac mini mid 2007 (A1176) which doesn't support wireless n, would it be possible to replace the internal card with a wireless n card from a newer mini? I found the post here http://www.ifixit.com/Answers/View/13885... but the link is broken and the quickertech.com website doesn't have any wireless cards for mac minis only for mac pros/mac books
Score
renan
37
Answered
yes. No problem.
Drivers are already in the installation of mac OS...
(universal installation)
Score
Toon B
13
Answered
0
Score
Toon B
13
Answered
The Atheros AR9280 was seen as a genuine AirPort-card by OSX...
...in 10.6 Snow Leopard
...and in 10.7 Lion it could even do AirDrop...
...until 10.7.3 that is...
10.7.3 for some mysterious reason lost it's ability to detect the AR9280 at all...
...the AirPort-icon in the menubar is blank, and it lists "no compatible hardware"...
Oddly, when restarting the Mac mini in 'Rescue mode' (pressing Apple(CMD)+R during startup), AirPort instantly connects using that same AR9280 card... ???!!
...but that doesn't last if you start up 10.7.3 the normal way.
So... after a lot of fiddling around I found the solution is quite easy :
1- reinstall the IO8211Family.ke
if you only need WiFi-connection, that will do, but...
...if you also want to use AirDrop, you need to do step 2 also :
2- only after doing step 1, you will be able to successfully reinstall the IO8211Family.ke
It is mind boggling why this works (but it does) because :
- directly reinstalling the IO8211Family.ke
- the IO8211.kext from 10.7.3 appears to be exactly the same as the one from 10.7.2 ; they have the same version number (4.1.2) and have been created and modified at the exact same date...
You might want to use the special .kext-installer ; you can find it here :
