A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Questions View all
MacBook doesn't wake after closing lid unless I reset smc
Hello,
I’m having some troubles with my 2017 non-touchbar macbook pro. The macbook works operates fine but once I close the lid, I can’t wake the computer unless I reset the SMC holding CTRL-Option-Shift-Power. As long as I don’t close the lid, I can sleep from the power menu and wake it by pressing any button the keyboard. I’m thinking it’s a problem with the lid sensor. This obviously gets very annoying since I cannot close the lid without having to completely reset the smc and reboot every time. Could anyone help me out?
Score 1
6 Comments:
Bumping for answers :(
by
In my case, I've observed by using an external monitor that the internal display disappears in MacOS. I don't know if this can help you...
by
By the way, I have this problem in a Late 2016 MBP 15"
by
Hi James, Have you found the solution to this problem yet? I'm experiencing the same thing with same model year mbp.
by
I had the same problem. I turn off power nap and it works
by
Show 1 more comment
Add a comment
I remember watching a video posted by Louis Rossman on an issue like this. I believe it was a sensor used to detect when the lid is opened. It uses a magnet and when the sensor goes bad, it doesn’t wake up the display. Try connecting it to an external display and see what happens.
Add a comment
Having the exact same problem here with a MacBook Pro late 2016 with touchbar.
I think it has something to do with the serie of problems people experienced since the the 10.15.4 update (Kernel Panic on wake up). https://discussions.apple.com/thread/251...
I managed to work around the problem by disabling Power Nap in the Energy Saver control panel and then by turning off the sleep mode altogether, but yet I still need to reset SMC everytime I try to restart after the lid has been closed.
Very annoying.
Add a comment
Same problem here for A1708 Macbook pro. History: Macbook did not turn on at all and a repair shop diagnosed, that i needed the logic board to be replaced. I found it way too expansive. One year later I changed the logic board by myself. The spare part is a used but okish logic board. Now, the mac works and i could safe my data and make a factory reset. However if i close lid, the mac book turns off screen but does not go to sleep. If i turn it off and turn it on without closing lid, all is good. When i turn off and close lid I cannot turn on again. I always need to power on with smc reset.
Some guys said its a problem with battery cable, but i checked it and it does not make any sense. Maybe something with the display cable? Or lid sensor? But where is this sensor?
1 Comment:
Yeah I listened to the same guy, bought a new battery cable and didn't work...
by
Add a comment
Any update on this? I am facing the same issue.
Add a comment
Add your answer
james kang will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 57
All Time: 2,287
