The current line of iPod touch comprises seven (7) different generations.
2618 Questions View all
What is the typical success rate for Isopropyl Alcohol?
What is the typical success rate for Isopropyl Alcohol (91%) for water damage?
Score 1
Add a comment
Chosen Solution
It would depend on whether or not the unit was powered up at the time water was applied to the iPod. If powered up and left that way (turned on--battery installed) for any length of time it probably won't help. On the other hand it doesn't hurt to try and you might get lucky.
Score 3
Add a comment
Most Helpful Answer
I have used it for several years cleaning out boards and other electrical parts with no issues, i have not seen any water residue left behind. You can purchase pure alcohol at some grocery stores but it runs about 20 dollars for a 750ml bottle typically its about 94-99% Alcohol.
Score 3
Add a comment
Add your answer
Davin Ludwig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 940
