A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines released in 2009.
55 Questions View all
Laptop not turning on, but the quickplay button lights on.
My Dell Studio 14 does not turn on. when I pressed the power button, the quickplay button lights on for a few seconds and nothing happens after that. there are no sounds at all. is it related to motherboard failure??
Score -1
Add a comment
Chosen Solution
You did not specify the model number of your unit so I've provided a link to the 1435 service manual. I hope that is correct.
http://support.dell.com/support/edocs/sy...
Score 2
Add a comment
Try to turn on your laptop without the battery on (only with the plug adaptor).
If this doesn't work, it is probably a hardware issue (although more inspection is needed before reaching this conclusion).
3 Comments:
I've tried. i even tried the upside-down trick but it didn't work.
thank you.
by
What is the make and model of your laptop?
by
mine is dell studio 14.
by
Add a comment
Add your answer
Ran John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,145
