Score
Avatar
jaclyndiane
13
Asked
replaced a failed hard drive and it still won't boot
History
about a year ago my iBook would freeze and i would have to reboot it constantly. Eventually It wouldn't boot at all and would just stay on the gray or blue screen. I took it to the genius bar and they told me that my hard drive was dying. I then took it to someone who said they could replace it for around $700. No. Thank. You.
So I just got around to my little project yesterday. Took it apart and replaced the 30GB hard drive with a 160GB one, and also increased the ram with a 520MB ram chip. It was all very straightforward and simple, thanks to this awesome website.
But when I got to the part where I needed to install OS x 10.4 Tiger, I ran into the same problem that I had before I replaced the hard drive. I inserted the disk and held down the option key while restarting the computer. An OS X icon appeared with a swirly arrow on the left (like a refresh icon)and a right pointing arrow on the right side. When I clicked the right pointing arrow it went to grey screen, then blue screen. I tried restarting it while holding down the C key and same thing.
BTW, my iBook did not come with Tiger. I think it came with Jaguar (10.3.2 maybe?) I bought the highest version of OS that my 800MHz processor can handle, on ebay. It is not a black disk but a grey one that says "for G3, G4, and G5 computers" or something like that. Can't tell you for sure because the disc is now stuck in the optical drive.
Can anyone tell me if there could be some other problem besides the hard drive? Am I installing the wrong OS? And how do I get the darned disk out of the drive if it won't boot? Is there anything else I should be considering?
Sorry for the long winded question, but I am very frustrated. Please help!
Edited by
Long winded questions help us spot what may be wrong. Tell us more about the install disks.
mayer,
Thanks Mayer! It was just one grey disk that said "for G3, G4, and G5 computers." I think that retail disks are black and the disks that come with an Apple computer are grey right? I asked the seller if I would be able to do a fresh install on a blank hard drive and he assured me that there would be no problem.
jaclyndiane,
Like I mentioned, I don't think having the wrong disc explains the problem. The disc showed in the option menu, so we know your laptop can read it. If the whole problem was having the wrong disc, it would have booted further and told you it's the wrong one, not stopped on a blue screen.
rdklinc,
Post Answer
2
Score
Avatar
rdklinc
15.3k
Answered
PermalinkHistory
Hi! If you hold down the trackpad button while powering on, it should kick out the disc.
I hate to say it, but I've had several slower-speed G4 iBooks come up with a problem like that, i.e. seems to work in option mode, but whatever you do it just gets to a blue screen. The conclusion in most of the cases has been, for a lack of a better explanation, that the board is bad.
You can rule out your optical drive failing to read the media by connecting a firewire external optical drive and booting from that, or another really good test would be to boot from another Mac's hard drive or optical drive while connected via firewire in target mode. If your machine runs fine off of a remote machine's hard drive, you know your board is good, so obviously that would be a good test.
I don't think you necessarily have the wrong installer media...if it was just the wrong disc, it should at least load further and then tell you it's the wrong one. Having the wrong installer media shouldn't cause the computer to freeze on a blue screen.
Also, I would remove the battery, Airport, and the extended RAM you just bought, just to rule those out, and then immediately reset the PMU and PRAM, and then see if it boots any further off the disc.
Good luck, and let us know what happens!
"Also, I would remove the battery, Airport, and the extended RAM you just bought, just to rule those out, and then immediately reset the PMU and PRAM, and then see if it boots any further off the disc." Can you elaborate on this? How do I reset the PMU and PRAM? I'm not super tech savvy so a lot of this stuff is new to me.
jaclyndiane,
Score
Avatar
Xen
387
Answered
PermalinkHistory
To reset the PMU on an iBook you need to shut down the unit. Remove all cords from the ports, including the power adapter. Remove the battery from the bottom of the computer. Then hold down the power button for 5 seconds. After this go ahead and put the battery back in and plug the computer into the power adapter.
The PRAM reset is holding the command, option, p and r keys down while the computer is booting. You will know you have done this correctly because about at the apple screen the unit will restart and you will here the startup chime happen again.
Best regards,
Xen
Also you may be able to eject the disk from the option boot screen. Just try holding the eject key for a couple seconds when it comes up.
Edited by
Thanks and welcome Xen. Your input is appreciated and you get an up vote from me. Sometimes we forget that people don't know how to reset the PRAM or PMU.
mayer,
Hi and thanks Xen the answer for the freezing was correct i had the same problem and i went ahead and reset PRAM and now it let me install OS X without freezing restored macbook thanks.
matt,
0
Score
Avatar
Jen Morris
Answered
PermalinkHistory
So happy to find this thread! The same fix just worked for me.
Add Your Answer
