6
Score
rdklinc
16.6k
Asked
Sometimes won't power on, only has black screen & power light
Hi! I've got a 15" aluminum Pro that is not behaving. Typically when powered on, the optical makes its startup noise, the screen stays black, and the sleep light glows. The chime noise does NOT sound. Occasionally when I try various things such as reseating/chang
My first thought is that this machine may have the Nvidia GPU issue, because it is within the range of machines that could potentially have the issue, and that issue is becoming more prevalent in general. However, I've dealt with many of those machines, and they usually do chime and act as if they are working, aside from the black screen, whereas this one goes into the odd mode I've described above, with no chime. There is no external video when it's in this mode, but external video works fine when the machine is working.
Does anyone have any ideas, and does anyone have an opinion as to whether or not this could still be the Nvidia issue? My next step is to replace the DC-in board, but if it seems likely to be the Nvidia issue I'll take it to the Apple store instead (because it's within the 4 year window, and they would replace the board if it qualifies).
Thanks!
John
4
Score
mayer
148.5k
Answered
Accepted Answer
It looks like the test may be available on Torrents. Will let you know if I can get a successful download. This would be a great time saving tool if we can get it. http://www.torrentreactor.net/search.php...
SIMRAN with all do respect, at times the computer will run. rdklinc stated in his question at times it will run for most of a day. Furthermore for most Apple service centers the computer will need to be running to run the test and approve of the repair. Interestingly, it appears, the program writes it's results to the hard drive on the computer being tested as well as to the device being used to test it. In other words it is visible how many times the test has been run and the results of those tests when running the program.
I've seen Apple do the testing many times (although I haven't paid as much attention as I wish I had) but I can definitely say that the test does run from the diagnostic drive even when the screen is black. In other words, a Pro with the Nvidia defect still has enough basic functionality to write to the diagnostic drive, after which the Apple employee looks at the test results on another machine and takes note of whether the GPU has been pronounced dead or not. Like I mentioned, I'm not confident this particular machine has the Nvidia issue, in which case the test likely will not be able to run on the machine, and they will likely pronounce that the computer has some other issue. But we will see, and I'll post what I find out.
The place I use for downloads does not have it. Maybe someone else can get it and OldTurkey can put it on his server.
Be careful though -- I believe it's a tool that Apple sees as "Apple only", so I'd hate to see anyone get in trouble downloading/usi
3
Score
SIMRAN
2.6k
Answered
this is the best way to go there in apple store for checking if this model has Nvidia 8600M GT graphics then they will replace it within the 4 years of purchase of this laptop.
MacBook Pro 15-inch and 17-inch models with NVIDIA GeForce 8600M GT graphics processors
MacBook Pro (17-Inch, 2.4GHz)
MacBook Pro (15-Inch, 2.4/2.2GHz)
MacBook Pro (Early 2008)
These computers were manufactured between approximately May 2007 and September 2008.
0
Score
Answered
Have you pulled out the optical drive? No chime means that your machine is not passing POST hardware tests. Try removing optical drive.
Majesty,
When you say that the machine works normally then goes back to sleep mode, do you mean after a reboot or during operation?
Majesty,
It didn't make a difference. I've seen a zillion machines with bad or no opticals that would still boot...have you seen a bad optical stop a Pro from booting?
rdklinc,
I believe it's generally been when it's first powering on or rebooting. But it may have done it once when it was already on...I don't recall though.
rdklinc,
I have never ran into this problem myself. Just a recommendation since you have removed/tested everything else.
Majesty,
+ Well thought out, highly detailed question. When it is working have you running iStat or similar to monitor temperatures? What is the exact model of this or the last 3 characters of the serial please?
ABCellars,
YJX. I want to take it to the Apple store to be tested for the Nvidia defect...I'm just worried it'll start working again the second I get there. I really need to download the Apple diagnostic tool they use so that I can verify the problem myself....
rdklinc,
That's an early 2008 2.4GHz. I have no idea if they use anything but their regular ASD to determine if this is an NVIDIA issue or not. Do you know if they have a special tool for this or if it is their normal Apple Service Diagnostic disk for this era of computers/lapto ps? If there is no special NVIDIA diagnostic tool, you need ASD Dual Boot 3S123. It is about 3 Gb in size and needs loaded on an external USB drive. I have a couple ideas where to find this. Please let me know what you need I will try to find it for you.
ABCellars,
ABCellars, that sounds interesting. I would be interested in having that. Where can I get it?
Majesty,
Majesty my email is in my profile. I see none in yours. Send me an email, perhaps I can send you in the right direction.
ABCellars,
My email should be on there. But I'll send you an email shortly.
Majesty,
Can't see your Email either. ;/
Majesty,
Thanks old turkey. I'll email you. Thanks.
Majesty,
sent old turkey.
Majesty,
Show 9 more comments
