0
Score
Avatar
DESTRO24k
Asked
Can you swap LCDs between different 12" iBook G4s?
History
The LCD on my 12" iBook G4 1.33 GHz is cracked and I'd like to replace it with one from an 12" iBook G4 1.07 GHz. Is this possible? Also, can I swap the HDs between models? Thanks so much for your help!
Thanks so much everyone. This is all very helpful and exactly what I was hoping to hear! Cheers.
DESTRO24k,
Post Answer
2
Score
Avatar
040304
4.7k
Answered
PermalinkHistory
Yes you can do it.
Here is one place that has instructions
www.ifixit.com has instructions also. Look here
Edited by
Score
Avatar
lemerise
16.2k
Answered
PermalinkHistory
Yes you can do it and you can even use a 12" iBook G3 LCD screen if you use all your G4 cables.
Score
Avatar
Anthony4
59
Answered
PermalinkHistory
There is a potential problem with replacing screens in the 12" G4 1.33.
If the existing screen is manufactured by ChiMei, then it seems that the video (LVDS) cable is sometimes specific to that screen and must be changed as well.
See this answer
Anthony
0
Score
Avatar
rdklinc
15.3k
Answered
PermalinkHistory
This is irrelevant to the 12" model, but concerning 14" iBooks, the video cables in certain models require a screen with a "big" video connector (about 2" across), rather than the "small" connector (about 1" across) that all 12" and most 14" iBooks have.
Anyway, again, just a word of caution for 14" iBook owners -- pop the back off the screen casing first, and take note of the connector size before purchasing a screen.
rdklincorporated, yes you can swap the 14" wide connector if you have the matching LVDS cable. I've done it many time using a 14" ibook G3 screen and installed it in a 14" ibook G4. The're a small mod to do to the LVDS connector that connects to the logic board cause the angle connection is slighty different but the cable connector and the mobo socket are the same.
lemerise,
Add Your Answer
