0
Score
Avatar
Atilla Taskiran
Asked
Display Data Connector on Logicboard broken
History
Hello there,
it just happened to me today. I broke the data cable connector part on my iMac 27". Is there anyway to repair it, because its actually on the logicboard itself.
I didn't know that I pulled off the display cable with its socket out of the logicboard. I saw that later when I wanted to put everything back on.
Here is a picture:
http://f.cl.ly/items/3u2S290N22090E1R0N0...
Please post a photo of the problem again with a larger circle. It looks like you've cover up what we need to see.
mayer,
any updates on this? Just did the same thing to a 27" iMac - need to look into fixing as the logic board is crazy expensive.
Brian Werner,
Helllp I have the same problem. I snapped two pins off. I wanted to sodder the pins back, but I sneezed and I cannot find them anywhere.. Anyone know a way I could improvise pins from somewhere else? Regards
meinthyme,
What ever happen? I have the same problem and Symutech says it's un reparible.
Christine Ebertshauser,
Post Answer
2
Score
Avatar
TommyJames337
1.1k
Answered
PermalinkHistory
Oh dear. . . lol
It appears as though you've not only removed the connector, but along with it, one of the pins.
A patient and creative solderer with skill could possibly fix it, but it would be tricky.
In cases like these, I believe they're fixable. I've done a few repairs with broken connectors on Apple logic boards myself.
There's only so much we could write to you on the Internet. Haha. If I had it right here, I'd start soldering away! You've just gotta find an engineer who's willing to take a look at it. :)
Edited by: TommyJames337 ( )
Soldering things such as that are best done under a stereo microscope and a soldering iron with a 1/64" conical tip.
ABCellars,
Absolutely!!! :) Well said.
TommyJames337,
hello there, do you guys have any pictures of your work? do i have to solder everything pin by pin or just pin everything at once? cheers
Atilla Taskiran,
I would use solder paste instead of solder wire for this. Are you going to try to repair this socket or install another one? Have you previously soldered under a stereo microscope before?
ABCellars,
I would find someone who can do this for me. I never soldered anytime before. I'm going to replace the socket, i bought a new socket from digikey: http://search.digikey.com/scripts/DkSear... What do you mean by solder paste? The pins on the socket have to be carefully soldered to the Logicboard right, i mean every pin piece by piece? I cant place just a paste by one stripe right? Sorry for my bad english. I hope you understand me. Cheers from Germany
Atilla Taskiran,
Show 1 more comment
0
Score
Avatar
Amir ahmed
Answered
PermalinkHistory
the quality of these pins is very poor, the same problem happen to me so i bought a proper lcd conecter from ebay
www.ebay.co.uk/itm/APPLE-imac-27-inch-internal-lcd-connector-FI-X30SSL-HF-/180750151856?pt=UK_Computing_Apple_Mac_Accessories&hash=item2a158c70b0#ht_1081wt_1413
and get rid of all the old pins and solder the new conecter with abetter quality pins
good luck
Omar
0
Score
Avatar
meinthyme
Answered
PermalinkHistory
Ya this is some bs problem. Im convinced apple booby trapped the dam imac. There is no logical reason to design a dam cable snap tension to be held down by a microchip and then to have reverse clamps which no other manufacture uses. Most ppl cause this problem unsuspecting a retarded design.
The first thing to do is
Dont rip any more pins off.
Save the ones that got torn off.
If two adjacent pins were torn along with the tracing lines/pads U R SCREWED.
Any1 good with a soddering can easily fix this if the dmg is minimal. But soddering without trace lines into the lobo is impossible.
0
Score
Avatar
Answered
PermalinkHistory
I had saved my one trace that came off and the first people I sent it to to help (simutek) lost it! I would have had this fixed way sooner if they hadn't. The Computer Gurus had to do extensive searching to find a pin that would work like the original. Like I said, they were hard to come by, took 4 months. You could find logic board a dead with the same pins but you will still pay more in the long run after paying for the board and the services. Make sure you keep the ins taped or in a bag. Easy to lose
Add Your Answer
