0
Score
Avatar
matthew
Asked
Display problem: Black appears to be red, external display works.
History
So I have a macbook pro A1211. The display has crazy redlines whenever it is suppose to be black, other colors look fine but, but black appears red.
however, an external display worked fine!
So I replaced the display data cable... nothing.
I replaced the LCD..... nothing
I unplugged the backlight and shined a light on the screen to see the red lines were still there, so the backlight/inverter is not the problem.
Which leaves the logic board =( =(
Is this correct now I need to replace the logic board?!
Edited by: Andrew Bookholt ( )
Post Answer
3
Score
Avatar
remacberlin
7.6k
Answered
PermalinkHistory
I suggest a hard, amored look at the LVDS socket on the logicboard. When an external screen shows a clean picture, the GPU is not at fault.
I have looked at it, I don't really know what I am looking for, looks fine, but yes I agree that socket is probably faulty, and the only way I could fix that would be to replace the logic board right?
matthew,
First I would try to clean the socket with a toothbrush and alcohol and then reconnect the cable. Sometimes they build up a film that makes for a poor connection. Replacing the logic board is expensive so we want to make it the last thing we try.
rj713,
Do you think that could work? What could have caused the socket to get dirty?
matthew,
I'd at least give it a try. Would be careful about the toothbrush though, the pins inside are quite delicate.
remacberlin,
no change, this must mean there is a problem between the gpu and connector on the logic board
matthew,
Show 1 more comment
0
Score
Avatar
nick
15.7k
Answered
PermalinkHistory
First, take your computer apart and check if the display cable is connected to the logicboard
Next, consider replacing the LVDS cable
If that doesn't work, chanes are the screen is bad or the
Lucky you, you don't have a NVIDIA plagued one from my limited research, so that eliminates that
Did you read my description?!!!
matthew,
Add Your Answer
